Clothes have to be ran through the dryer several times to get completely dry. The heating element comes on (on part briter than the other) and cycles off after a minute, but the clothes take several times through a whole cycle to dry. Not sure if I should replace the element or I have one or more bad thermostats. Ed
Had the same problem replaced the heating element becuase one of the elements were broken. ALso check your vent that exits the house it may be clogged, perfect time for bird nests......
THIS FORUM IS DEAD!!!!!!! |
