wmpalovick
#1 Posted : Wednesday, April 8, 2009 12:33:11 PM(UTC)
wmpalovick
I recently purchased 2 door hinges for my upper oven. Both springs had snapped in the old units. I replaced the hinges and now the door does not pull completely closed. There doesn't seem to be an adjustment. It needs about 1 inch more pull to close and shut the light off. Any ideas?
woodchuckie
#2 Posted : Wednesday, April 8, 2009 1:27:06 PM(UTC)
woodchuckie
Make sure the door is pushed to the right spot on the hinge arm. There may be a screw to hold it in position.
