I recently purchased 2 door hinges for my upper oven. Both springs had snapped in the old units. I replaced the hinges and now the door does not pull completely closed. There doesn't seem to be an adjustment. It needs about 1 inch more pull to close and shut the light off. Any ideas?
Rank:: Advanced Member
Make sure the door is pushed to the right spot on the hinge arm. There may be a screw to hold it in position.
