Once I reset the oven with the curcit breaker I tried the oven again. Tried to put oven on 350 and temp keeps going up, up, up til F2 flashes. What do I do to fix this?:confused:
Could find no info on this unit, please check your Model Number. Usually they have a letter or 2 at the start. First thing to check would be your temp sensor. http://www.applianceaid.com/oven_temp_sensors_help.htmlAlso could be the relay contacts which control the element are welded together or the control board is shot. |
THIS FORUM IS DEAD!!!!!!! |
