larsenm
#1 Posted : Tuesday, April 7, 2009 5:26:54 PM(UTC)
larsenm
Once I reset the oven with the curcit breaker I tried the oven again. Tried to put oven on 350 and temp keeps going up, up, up til F2 flashes. What do I do to fix this?:confused:
#2 Posted : Wednesday, April 8, 2009 3:32:40 AM(UTC)
Could find no info on this unit, please check your Model Number.
Usually they have a letter or 2 at the start.
First thing to check would be your temp sensor.
http://www.applianceaid.com/oven_temp_sensors_help.html
Also could be the relay contacts which control the element are welded together or the control board is shot.
