soonerhokie
#1 Posted : Sunday, September 4, 2011 11:27:12 AM(UTC)
soonerhokie
My Bosch oven does not heat up. The stove top and the broiler are fine. I suspect the igniter. I have the part, but don't know how to access the wires to install it. I had looked around the web to find general instructions on installing an igniter, and it seemed easy.
I took off the bottom of the oven to access the igniter, but the wires go behind the frame so I cannot access it. I have included a pic. Do I have to go through the back panel to access the igniter wires. Or, more generally, how do I access the igniter wires.
Thanks for the help!
[IMG]http://www.freeimagehosting.net/5d2c8[/IMG]
There is no way I can see to remove the aluminum frame at the bottom in the pic.
soonerhokie
#2 Posted : Sunday, September 4, 2011 4:39:09 PM(UTC)
soonerhokie
I found it. For those that may need to know, the wires are accessed from the back of the stove. You just need to remove/loosen the back plate.
