Hi, I have a Maytag fridge that is not cooling at all. I put a thermometer in it and it says 60 all the time. However, the freezer is working fine. Hubby took the panel off the back and cleaned out the whole inside which did have a lot of dust. He cleaned the pan underneath. But, nothing seems to work.
Any ideas? Lori
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Where is the flap to adust? Sorry to be a pain. :) Lori Originally Posted by: woodchuckie  The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
