No light in the refridgerator section, but there is light in the freezer and on the door. Changed bulb, but still no light.
Rank: Administration
Groups: Administrators
Please recheck your model number for parts.Please make sure to get the model number off the appliance itself. Click to locate model numberIt could be the light switch or socket. If you pull out the switch you can check it for continuity. It should have continuity when the button is not pressed.
