Kent Becker
#1 Posted : Thursday, September 1, 2011 7:57:09 AM(UTC)
Kent Becker
There is a grinding or rubbing noise in the machine while running with a load. Makes no noise with no load. Also the machine will stop part way through the cycle. I push the start button and the wash resumes. If the bearings on the drum are bad will it cause the motor to stop.
sidfink43
#2 Posted : Friday, September 2, 2011 3:54:13 PM(UTC)
sidfink43
The bearings are the likely problem on this model, but they should not stop the motor from running.
This is a very troubled machine, very, very troubled. My advice is almost always replace it, the fixes are not worth it.
Noisy drum dryer (Dryer Repair)
by bzk 7/6/2014 10:34:15 AM(UTC)
Noisy Drum (Dryer Repair)
by russham22 12/7/2010 6:23:21 AM(UTC)
Noisy Drum Maytag Mde6400ayw (Dryer Repair)
by mikeg1303 2/4/2009 6:58:55 PM(UTC)
