I tried to look at other pages for my question but didn't find one, I'm sure it's there somewhere. soo.... My Dryer won't rotate until I push it, but the motor is running as you can hear it. After a couple of minutes, it will turn off and won't come back on for a couple of minutes. I assume it is shorting out and has to cool down until restarting.
The drum is hard to rotate on it's own, even with me spinning it. It seems like the drum is off track but it doesn't seem as if it has a track that it rotates on. So do I need to replace the Drum rollers, Front Bearing, Belts & motor?
THIS FORUM IS DEAD!!!!!!! |
