jgwells
#1 Posted : Sunday, March 27, 2011 11:01:41 AM(UTC)
jgwells
My home washer will not spin on its own. I have to turn the basket clockwise 1/2 turn and then it will spin.
History:
It would not spin at all, so I changed the transmission.
It would not spin on its own. I have to turn the basket clockwise 1/2 turn and then it will spin.
Since then, I have taken it apart again to turn the clutch over because I thought I might have put it in upside down since there is a tab on one side of the spring longer than the other.
Currently:
It still will not spin on its own. I have to turn the basket clockwise 1/2 turn and then it will spin.
It washes fine. It spins great after I get it going by turning the basket. The brake seems fine, the white plastic piece releases it and it turns good. I put the spring of the clutch on the opposite side of the white plastic piece that releases the brake. I have tried the clutch both ways rightside up and unside down and get the same result: I have to turn the basket clockwise 1/2 turn and then it will spin.
Parts and Schematic:
http://jgwells.com/WhirlpoolWasher1.pdf
GST9679PB0'); return false; " href="http://www.appliancepartspros.com/search.aspx?model=GST9679PB0" target="_blank">Model GST9679PB0
Provide a solution and I owe you my first born.
JGWells
sidfink43
#2 Posted : Tuesday, March 29, 2011 5:14:23 PM(UTC)
sidfink43
Normally the clutch is the problem here, but if you sure it is ok, check the drive block. You will need a special spanner wrench to get to it.
