My wifes oven just died. Put breaker back on and stove top is working but oven is out as well as clock controls. Was going to order part#AP3764682 EOC clock, but was wondering if it could be something else? There was a spark before it went off, out of control clock,, Would appeciate help, for I can not afford a repairman, I recently got laid off. Kevin
If the display is out, the EOC ( AP3764682) is most likely the problem. If you want to check, you can try taking a look at the electronic board and you will probably find a black spot where a component was located before the spark. Could have been a voltage spike, or just it's time to go. But the EOC is all that's really in that circuit.
THIS FORUM IS DEAD!!!!!!! |
