kevin lombardi
#1 Posted : 16 years ago
kevin lombardi
My wifes oven just died. Put breaker back on and stove top is working but oven is out as well as clock controls. Was going to order part#AP3764682 EOC clock, but was wondering if it could be something else? There was a spark before it went off, out of control clock,, Would appeciate help, for I can not afford a repairman, I recently got laid off. Kevin
TechnicianBrian
#2 Posted : 16 years ago
TechnicianBrian
If the display is out, the EOC (AP3764682) is most likely the problem. If you want to check, you can try taking a look at the electronic board and you will probably find a black spot where a component was located before the spark. Could have been a voltage spike, or just it's time to go. But the EOC is all that's really in that circuit.
#3 Posted : 16 years ago
Here is a wiring diagram and a tech sheet
ftp://ftp.electrolux-na.com/Pr...pringfield/316255329.pdf
ftp://ftp.electrolux-na.com/Pr...ingfield/316218513en.pdf
As TechnicianBrian said check to see if you can find out exactly where the flash came from, though odds are high that even if it was not on the board itself, it took the board out.
When you say the surface elements are OK I am assuming that the indicator lights for them are also working. If not, you may have an electrical problem.
Note it is best to check the power with a meter.
