My Whirlpool fridge side by side freezer is not cooling at all. Fan and lights work, no crazy sounds at all from the compression pump. But no sounds at all from the pump. Do you think the defrost timer has gone bad?
Model #- EDZZPOXFNOL
The fridge was purchased in 99
I cannot find any info on the given model number, please check it. It does not look like a valid Whirlpool number. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman I cannot find any info on the given model number, please check it. It does not look like a valid Whirlpool number. Sorry on the number. Here is the right one ED22POXFN01 I heard a clicking sound , I believe it is the starter relay for the compressor. I took the part out and shook it, hearing a rattle sound and small bits like a pepper shaker starting pouring out. Thoughts?
Originally Posted by: denman Yes my bad. It was a Q and not a O. I will order the part:)
