tmagna
#1 Posted : Wednesday, April 1, 2009 7:29:50 AM(UTC)
tmagna
no spin cycle it fills up with water and then it agitates then it pumpes the water out but when it is sopose to spin the motor just humms and you can smell like the motor is burning up and then it shuts down I took the belt off and ran it and the motor works fine in agitate cycle but when I bump it to spin It still does the same thing I think the switch on the lid is ok or then the motor would not evan humm the model I have posted it off the dryer door this is a stackable wash and dryer I didnt find any # on washed and I do not now how old this is just guessing thanks tony
#2 Posted : Wednesday, April 1, 2009 11:31:30 AM(UTC)
Most likely the problem is a bad motor.
- The part number for the motor is AP3219509
Here are the break down diagrams and Replacement parts for FRIGIDAIRE FLXG52RBS7 | AppliancePartsPros.com
tmagna
#3 Posted : Tuesday, April 14, 2009 5:56:52 AM(UTC)
tmagna
It turned out to be a bad switch ,controler for the washing machine I put a diferent motor in it and it did the same thing so then changed the switch and now it works thanks for the help tony
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
No spin cycle on washer...need help (Washer Repair)
by 1moretoy 11/4/2014 3:57:35 PM(UTC)
Frigidaire Stackable Lid Switch Bypass no spin cycle (Washer Repair)
by billumd 9/26/2014 6:51:48 PM(UTC)
no spin cycle so clothes stay wet (Washer Repair)
by pmt1231 6/3/2014 8:23:30 PM(UTC)
Maytag Atlantis No Spin Cycle Replaced Thrust Bearing. (Washer Repair)
by MarkBe 12/21/2013 7:36:46 AM(UTC)
kenmore ~ no spin cycle (Dishwasher Repair)
by chrismo13 8/10/2013 12:42:54 PM(UTC)
No Spin Cycle (Washer Repair)
by KJH1961 1/16/2013 2:36:43 PM(UTC)
No spin cycle (Washer Repair)
by baldguywithagoat 10/8/2012 1:56:22 AM(UTC)
I replaced maytag mav6200aww brake, now no spin cycle (Washer Repair)
by jmlaudate 9/4/2012 4:28:43 PM(UTC)
Washer tumbles but no spin cycle (Washer Repair)
by jrwhitton 8/8/2012 9:13:05 AM(UTC)
Tumbles but no Spin Cycle (Washer Repair)
by Rob2001 7/23/2012 2:33:29 PM(UTC)
by John Foley 4/29/2012 11:46:11 AM(UTC)
No spin cycle or drain? Lid switch? (Washer Repair)
by 9n1Ed 4/27/2012 10:47:15 PM(UTC)
by firefly 4/27/2012 10:18:46 AM(UTC)
GE washer no spin cycle (Washer Repair)
by fsuglover 4/8/2012 4:41:33 PM(UTC)
