Roger Tiedt
#1 Posted : Tuesday, August 16, 2011 11:29:49 AM(UTC)
Roger Tiedt
Refrigerator upper door hinge has started binding and making noise. I removed hinge and lubed it, no help. I swapped the two top hinges and the freezer side continues to operate fine. The refrigerator top hinge appears not to be perpendicular(pin going into the door) when installed.
Any suggestions as to repair would be appreciated. THANKS!
adventura
#2 Posted : Tuesday, October 4, 2011 5:07:46 AM(UTC)
adventura
Hi Roger...did you ever resolve your refrigerator door hinge problem? Mine is making an awful noise opening and closing...seems to be the upper hinge. Any tips?
Thanks...Cheryl
Roger Tiedt
#3 Posted : Tuesday, October 4, 2011 8:22:14 AM(UTC)
Roger Tiedt
Thanks...Cheryl
I removed hinge and used a q-tip to wipe out anything in the hole for the pin. Applied lube(spray and packed hole with Dow Corning) It has helped about 95%. Good Luck!--Roger
