04 jeep
#1 Posted : Tuesday, March 31, 2009 3:35:19 PM(UTC)
04 jeep
Just purchased a brand new module for my ice maker that hasn't work in a couple of years. Plug all the harnesses in after installing and nothing, no water, no noices, no signs of life at all. I have water to the dispencer. What the heck am I missing?
Steve
TechnicianBrian
#2 Posted : Tuesday, March 31, 2009 6:01:03 PM(UTC)
TechnicianBrian
Do you have voltage to the ice maker? I have a Testing Modular Ice Makers that may offer some guidance to your repair. Give it a read and see it it helps.
04 jeep
#3 Posted : Tuesday, March 31, 2009 10:16:13 PM(UTC)
04 jeep
Thanks Brian,
Didn't take long for the module to jump to life.
A jumper wire inserted between test points T & H will bypass the bi metal thermostat and force a harvest cycle. If the motor does not run with the jumper in place, replace the module assembly. Leave the jumper wire in for the first half a revolution to verify the mold heater is working. Removing the jumper during the last half a revolution will allow the water fill valve to actuate. Failure of the mold heater to operate would indicate it needs to be replaced. An open mold heater will also prevent the water valve from operating.
Steve
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
