i have a maytag.washer ( agitator want work in wash cycle),,i have replace the thrust bearing (thrust bearing kit).washer spins ok ,just want wash the cloths ( motor running ok ). thrust bearing kit install correct also...i do need help with this one .......
Originally Posted by: hurst ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) i have a maytag.washer ( agitator want work in wash cycle),,i have replace the thrust bearing (thrust bearing kit).washer spins ok ,just want wash the cloths ( motor running ok ). thrust bearing kit install correct also...i do need help with this one ....... ......the trans stem wants to work but stops motor keeps running ,,someone please help me ,,is the trans going out ?
Originally Posted by: hurst ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ......the trans stem wants to work but stops motor keeps running , could trans. be going out ?:confused:
