zevfix
#1 Posted : Monday, November 19, 2007 5:01:31 PM(UTC)
zevfix
The gas oven takes way too long to heat up. There is also a smell of gas at times when the oven is turned on. This just started happening recently.
The broiler appears to work fine. The burners work fine as well.
I removed the lower drawer and the cover panel behind it and located the Oven Valve. It appears that when the oven is on and I wiggle one of the electrical contacts on the Oven Valve I can hear more gas passing through the valve. Before purchasing the $100 part I want to be sure that this is the problem. Anyone experienced this and solved it successfully?
Thanks.
#2 Posted : Tuesday, November 20, 2007 3:43:37 PM(UTC)
Most likely the problem with your oven is a bad igniter, not the gas valve.
You can learn how the oven igniter works from the one of previous posts here: http://forum.appliancepartspros...1897-oven-wont-lite.html
- The part number for the oven igniter AP205873
- Here are the break down diagrams for the Jenn Air range Model SCG20200W
zevfix
#3 Posted : Wednesday, November 21, 2007 7:15:11 PM(UTC)
zevfix
Gene,
Thank you. Your assessment was spot on. The igniter was bad - cracked as a matter of fact. I replaced it with the one for the Broiler to make sure and the oven works. I will now order an igniter.
Thanks again.
Guest (4)
