csky
#1 Posted : 16 years ago
csky
convection fan doesnt come with convection cooking,
I knowticed that the convec. fan was not working when on convec. bake . The convec. element works .
We just purchased this on craigslist. everything checkout ok before moving range to our place.
The manual says that the fan stops when the door is opened ,so i held the button in ,and noticed the convect. element working and the fan was,nt .
Any ideas out there .
#2 Posted : 16 years ago
Check the motor itself for continuity. Check all wires and the door switch. Also there can be some delay for the motor to start.
P.S. The model number you posted does not come up. Is it an American model?
csky
#3 Posted : 16 years ago
csky
Howdy Gene ,thanks for your response, Ive looked the range over to verify model # and origin of build . Cant find origin of build ,but the manual gives U. S. contact info. The only luck i,ve had with using the model # is using the 1st 5 characters . Thanks again
#4 Posted : 16 years ago
Look for the model number on the range frame behind the bottom drawer or on the oven door frame.
csky
#5 Posted : 16 years ago
csky
Thanks Gene , I,ll give it a whirl ,and let ya know the score.
