I had to replace the Adaptive Defrost Board about 3 years ago then my freezer started to experience the same defrosting problems, so I recently replaced the board again. The fridge worked initially (for 3 weeks) but has started to frost up again. What could be causing the Adaptive Defrost boards to fail?:confused:
Did you check the defrost thermostat for continuity? Did you visually inspect it? The new thermostat comes as a part of the heater assembly. - The defrost heater assembly Part number: AP4069923
