jude63
#1 Posted : Thursday, August 11, 2011 9:55:52 AM(UTC)
jude63
I had to replace the Adaptive Defrost Board about 3 years ago then my freezer started to experience the same defrosting problems, so I recently replaced the board again. The fridge worked initially (for 3 weeks) but has started to frost up again. What could be causing the Adaptive Defrost boards to fail?:confused:
#2 Posted : Thursday, August 11, 2011 3:06:44 PM(UTC)
Did you check the defrost thermostat for continuity? Did you visually inspect it?
The new thermostat comes as a part of the heater assembly.
- The defrost heater assembly Part number: AP4069923
