madoian
#1 Posted : Sunday, March 29, 2009 8:41:03 AM(UTC)
madoian
I am having trouble replacing the door handle on my KHMS155LSS4. I cannot access the screws. I viewed a video of similar problem but the model was not the same.
TechnicianBrian
#2 Posted : Sunday, March 29, 2009 9:10:05 AM(UTC)
TechnicianBrian
You need to split the door by removing the inner frame cover called the choke cover. Use a putty knife to work around the edge between the inner frame and the outer door frame until you can pull it free. You may be able to get to the screws at this point, but if not, the outer panel is held to the metal choke by many tabs. If you break a couple, not a big deal. Once the handle is removed, put it all back together.
Replace door handle (Microwave Repair)
by thunderbolt 9/2/2011 6:22:51 PM(UTC)
ge microwave jvm1740dmww1 process to replace door handle (Microwave Repair)
by DSG 6/15/2011 5:13:14 AM(UTC)
Dismantle and replace door handle (Refrigerator & Freezer Repair)
by stemwinder 3/6/2010 2:11:56 PM(UTC)
GH9176XMS1 Replace Door Handle (Microwave Repair)
by ron305 2/15/2010 9:01:24 PM(UTC)
by Napoleon 7/22/2009 6:58:49 AM(UTC)
axxis dryer - how do I replace door handle (Dryer Repair)
by christykarsten 5/6/2008 6:58:23 AM(UTC)
by larsonwells 1/5/2008 5:49:22 PM(UTC)
by btcsys 11/9/2007 12:36:51 PM(UTC)
