Are there any associated parts that I should order with new springs, or is it just the springs? Common problem I guess - door just falls, no tension.
The door springs ( AP2920972) should solve your problem. Make sure and look for the plastic spring bearings ( AP3010626) when you install the new springs. If they pop out or are broken, the door with make noise when opened.
