mancell
#1 Posted : Sunday, March 29, 2009 6:50:46 AM(UTC)
mancell
Are there any associated parts that I should order with new springs, or is it just the springs? Common problem I guess - door just falls, no tension.
TechnicianBrian
#2 Posted : Sunday, March 29, 2009 7:03:23 AM(UTC)
TechnicianBrian
The door springs (AP2920972) should solve your problem. Make sure and look for the plastic spring bearings (AP3010626) when you install the new springs. If they pop out or are broken, the door with make noise when opened.
