dvidler1
#1 Posted : Sunday, August 7, 2011 5:26:37 AM(UTC)
dvidler1
The washer will not enter rinse or spin cycle. It will fill, agitate and drain. The knob does rotate to the rinse position but never sprays water into the drum. I cheated the lid switch with a screwdriver to confirm this. I don't have a manual or diagram. Can anyone help.
sidfink43
#2 Posted : Monday, August 8, 2011 4:27:53 PM(UTC)
sidfink43
Your lid switch is probably dysfunctional. You will have to open it up to check things out with a meter.
Washer will not rinse or spin (Washer Repair)
by Ktaka23 4/9/2014 9:11:11 AM(UTC)
washer will not rinse right cloth still wet (Washer Repair)
by bob n jack 5/3/2012 3:23:15 PM(UTC)
Washer will not rinse (Washer Repair)
by stumpt 3/18/2011 4:24:10 PM(UTC)
Front load washer will not rinse/drain or spin out (Washer Repair)
by haroldlm 12/9/2009 9:15:50 AM(UTC)
washer will not rinse/ new timer replaced (Washer Repair)
by bak 10/22/2009 3:59:59 PM(UTC)
ge washer will not rinse or spin (Washer Repair)
by tmm313psu 10/2/2009 3:48:31 PM(UTC)
by jimbo0555 6/26/2009 5:20:11 PM(UTC)
by tempo1001 3/24/2008 1:54:13 PM(UTC)
