My frigidaire fdb126rbs2 will fill up and drain, but never cycles the wash. It makes no sounds other than the timer during the wash cycle. I figured this was the motor. Should I replace it or repair it?
First you have to find out what is wrong with it. Could be: 1. the motor - check it for continuity. 2. the timer - check that the contact for the motor is closed. 3. bad connection or a broken wire - check visually. If OK check for continuity. Here are your parts Replacement parts for FRG FDB126RBS2 | AppliancePartsPros.comHere is a wiring diagram ftp://ftp.electrolux-na.com/Pr...DF/Kinston/154441501.pdfCannot say if you should replace it. Both the motor and the timer are approximately $100 but it may be worth investing this amount of money if the rest of the unit is in good shape. You will need a meter. Do you have one? |
THIS FORUM IS DEAD!!!!!!! |
