drparrott
#1 Posted : 16 years ago
drparrott
4 yr old icemaker not producing ice. water running for cold water, but no ice. water does not appear to be filling ice tray.
woodchuckie
#2 Posted : 16 years ago
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the tube off the valve and watch to see if it drips.
GE Side by side icemaker not working (Refrigerator & Freezer Repair)
by Aleste 12 years ago
kenmore side by side icemaker won't eject ice (Refrigerator & Freezer Repair)
by manderso 13 years ago
Hotpoint side by side icemaker not working (Refrigerator & Freezer Repair)
by reen910 15 years ago
Whirlpool Side by Side IceMaker Overfilling (Refrigerator & Freezer Repair)
by jfreyling 15 years ago
GE Profile Side by Side Icemaker won't dump ice into bin-frozen (Refrigerator & Freezer Repair)
by spaisley39 15 years ago
Refrigerator Side by Side Icemaker (Refrigerator & Freezer Repair)
by ritabarbie 16 years ago
Kenmore side by side icemaker over fills (Refrigerator & Freezer Repair)
by mdg224 16 years ago
whirlpool refrigerator side by side icemaker makes little or no ice (Refrigerator & Freezer Repair)
by T-ROY 16 years ago
