drparrott
#1 Posted : Thursday, March 26, 2009 2:51:22 PM(UTC)
drparrott
4 yr old icemaker not producing ice. water running for cold water, but no ice. water does not appear to be filling ice tray.
woodchuckie
#2 Posted : Thursday, March 26, 2009 8:20:05 PM(UTC)
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the tube off the valve and watch to see if it drips.
GE Side by side icemaker not working (Refrigerator & Freezer Repair)
by Aleste 1/31/2013 3:51:41 AM(UTC)
kenmore side by side icemaker won't eject ice (Refrigerator & Freezer Repair)
by manderso 1/2/2012 4:44:20 PM(UTC)
Hotpoint side by side icemaker not working (Refrigerator & Freezer Repair)
by reen910 8/24/2010 3:56:38 PM(UTC)
Whirlpool Side by Side IceMaker Overfilling (Refrigerator & Freezer Repair)
by jfreyling 3/30/2010 7:25:59 PM(UTC)
GE Profile Side by Side Icemaker won't dump ice into bin-frozen (Refrigerator & Freezer Repair)
by spaisley39 3/15/2010 5:41:01 AM(UTC)
Refrigerator Side by Side Icemaker (Refrigerator & Freezer Repair)
by ritabarbie 8/28/2009 12:17:08 PM(UTC)
Kenmore side by side icemaker over fills (Refrigerator & Freezer Repair)
by mdg224 12/27/2008 12:43:21 PM(UTC)
whirlpool refrigerator side by side icemaker makes little or no ice (Refrigerator & Freezer Repair)
by T-ROY 11/6/2008 2:59:14 PM(UTC)
