Will I be able to pop the handle into the holes on the door by hand or do I need a special tool?
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Using a putty or a butter knife carefully remove #3 inner door panel. This will expose the two screws that hold the door handle. You can then replace the handle. Let us know how it goes...
