Casey Donlon
#1 Posted : Tuesday, November 20, 2007 2:50:06 AM(UTC)
Casey Donlon
When any of the burners on the range top are ignited, there is a strong odor of propane (unit configured for LP application). When the oven is turned on, the same odor of gas occurs. It seems that there is a gas leak in a line common to both the range top and oven but this line only gets pressurized when the signal is sent to release gas when operating either the range or the oven. Any ideas on where to look?
#2 Posted : Tuesday, November 20, 2007 3:34:11 PM(UTC)
Range/Oven Gas Odor (Oven Repair (including Ranges and Cooktops))
by Casey Donlon 11/20/2007 2:55:12 AM(UTC)
Belarus Casey Donlon 11/20/2007 2:45:49 AM(UTC)
