theodore
#1 Posted : Tuesday, March 24, 2009 10:13:40 AM(UTC)
theodore
The top element in my Kenmore built-in oven went out. The bottom works fine. I notice there is two screws in the back. So do i remove the screws and pull the element out and replace it with the new one or what steps should i take to replace it.
woodchuckie
#2 Posted : Tuesday, March 24, 2009 10:30:29 AM(UTC)
woodchuckie
That's about it. After you take the screws out you pull the wires out just a little and unplug them. Be careful not to let them fall through the opening. Might have trouble getting it back out. Plug the new one in and screw it down.
oven and brolier elements wont heat (Oven Repair (including Ranges and Cooktops))
by lizardqueen 1/17/2009 9:36:07 AM(UTC)
