Redstart80
#1 Posted : Sunday, July 31, 2011 11:21:04 AM(UTC)
Redstart80
My microwave went dead when i tried plugging it to another outlet. It was well in good working condition before it lost its power. I suspect it might be the fuse however I haven't pulled it down yet and check what is really wrong with it. Can you please help me and let me know what is normally the problem when a microwave suddenly looses its power. Thank you sir.
Microwave11
#2 Posted : Sunday, July 31, 2011 6:54:29 PM(UTC)
Microwave11
Fuse and door switches are a good place to start. There should be several switches or contacts located where the door hooks enter into the unit when you close it. If your door is off-center, and the door hooks are not making adequate contact, you will not get power to the unit. The fuse location is different in every model, check the wiring diagrams in the parts section for those specifics.
You can check the fuses and switches with a typical meter, guessing which switch is blown could get costly. Unfortunately i've had the same issue this weekend, only switching the power source didn't change anything. I also just finished checking all the fuses and switches I could find, still no direct problem on my end.
Good luck to you however.
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 8/18/2023 1:00:22 PM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 4/16/2023 11:55:25 AM(UTC)
Fridge - No power (Refrigerator & Freezer Repair)
by Guest 1/19/2023 7:36:28 PM(UTC)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 11/15/2022 9:25:21 AM(UTC)
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 10/12/2022 11:12:10 AM(UTC)
lg tromm dryer no power (Dryer Repair)
by Guest 8/25/2022 8:16:12 AM(UTC)
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 8/24/2022 2:40:22 PM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Maytag washer no power (Washer Repair)
by Guest 10/28/2021 12:07:08 PM(UTC)
