grice98
#1 Posted : Monday, March 23, 2009 10:20:09 AM(UTC)
grice98
I have a gas dryer that when the start button is pressed, it will start sometimes and sometimes it will make a humming sound. If I spin the drum a little by hand (not very easy to do) and then press the start button, it will work.
I have also removed the drum, belt, and Idler arm, so that the motor has no resistance and it exhibits the same behavior. If I take and turn the motor shaft while pressing the start button it will come on.
Any ideas? Thanks
#2 Posted : Monday, March 23, 2009 2:29:51 PM(UTC)
The motor needs replacing.
OR
The centrifugal switches on the motor are jammed up with lint.
OR
The centrifugal activating assembly is broken, also requires motor replacement.
