Ken Martin
#1 Posted : Tuesday, July 26, 2011 12:56:42 PM(UTC)
Ken Martin
Per DENMAN'S SUGGESTION, THE HEATING ELEMENT READ 10 OHMS AND THERE IS NO CONTINUITY BETWEEN THE COIL AND THE CASE. ANY IDEAS OF WHAT I SHOULD TRY NEXT? THANKS KEN
#2 Posted : Tuesday, July 26, 2011 4:09:37 PM(UTC)
Ken,
You may want to measure the current drawn by the dryer on each power leg. Confirm it with the rating on the dryer name plate. Post the results.
Breaker trips after 45 (Dryer Repair)
by Ken Martin 7/22/2011 7:39:35 AM(UTC)
