anitajones
#1 Posted : Friday, July 22, 2011 5:45:22 AM(UTC)
anitajones
hi i bought the defrost timer...put it in last night still have frost this mornig..just wondering if i was suppose to do dark blue wire with dark blue..the on that was on there was a brown wire ad orange!???
thanks
#2 Posted : Friday, July 22, 2011 6:08:52 AM(UTC)
Replacement parts for FRIGIDAIRE FRS23R4CB0 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the wiring diagram that comes up for this unit.
http://manuals.frigidaire.com/p...f/Anderson/240389610.pdf
Sorry but I do not understand most of your question.
Also the parts and the wiring diagram both show an adaptive defrost board not a defrost timer so I am not sure I ave the correct info.
Try forcing a defrost cycle (see the wiring diagram), that should clear the frost.
If the defrost heater does not come on then your problem may be elsewhere, either the heater itself of the defrost thermostat.
frezzer & fridge too warm (Refrigerator & Freezer Repair)
by NPANS 11/1/2016 10:15:58 AM(UTC)
exterior of panel between the frezzer door and the refrigerator door is burning hot (Refrigerator & Freezer Repair)
Belarus splash13 7/19/2014 7:44:36 PM(UTC)
frige and frezzer not working. (Refrigerator & Freezer Repair)
by cewmsjw 10/30/2013 7:44:02 PM(UTC)
frezzer back freezing up- fridge not cold (Refrigerator & Freezer Repair)
by murphy7513 10/4/2012 10:09:15 AM(UTC)
ice on bottom of frezzer (Refrigerator & Freezer Repair)
by robertcall60 8/28/2012 5:46:32 AM(UTC)
frezzer not frezzing, refrigerator not staying cold, water driping in bottom pan (Refrigerator & Freezer Repair)
by sandra j hackney 7/9/2012 7:49:11 AM(UTC)
Fridge and frezzer are not getting cold (Refrigerator & Freezer Repair)
by Kevin Hutchens 6/24/2012 12:43:49 PM(UTC)
No ice, warm fridge, frezzer ok, frost build-up (Refrigerator & Freezer Repair)
by alltrees 6/16/2012 12:13:21 PM(UTC)
frezzer not frezzing food (Refrigerator & Freezer Repair)
by kjhluisa07 6/8/2012 2:03:01 PM(UTC)
Frezzer not Frezzing but still cold (Refrigerator & Freezer Repair)
by surgecast 4/4/2012 7:41:36 AM(UTC)
in frezzer door water line (Refrigerator & Freezer Repair)
by cgirl11@gmail.com 11/20/2011 3:37:45 PM(UTC)
by anitajones 7/22/2011 5:45:22 AM(UTC)
frig & frezzer (Refrigerator & Freezer Repair)
by jamesrt 4/13/2011 5:17:27 PM(UTC)
Warm Frezzer (Refrigerator & Freezer Repair)
by anfurnee 3/16/2011 3:18:43 PM(UTC)
Wirlpool refrigerator Frezzer (Refrigerator & Freezer Repair)
by bikerxlc 8/26/2010 12:19:25 PM(UTC)
