bikerxlc
#1 Posted : Thursday, August 26, 2010 12:19:25 PM(UTC)
bikerxlc
Freezer will not 'self defrost' after 2 weeks running time. I manually defrost then everything works fine for 2 weeks....repeat. Do I need a new defrost timer???
#2 Posted : Friday, August 27, 2010 2:15:24 AM(UTC)
Replacement parts for WHIRLPOOL ED0GTQXKQ00 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Wiring%20Sheet%20-%202216709.pdf
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 6 in Section 11) till the fans and compressor turn off.
There is usuallya hole in the cover to let you do this.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Section 9) from the wiring and measure it for continuity, usually around 25 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 35 in Section 9) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
