jenny55
#1 Posted : Wednesday, March 18, 2009 9:57:59 AM(UTC)
jenny55
Roper electric dryer runs hot all the time, no low or medium heat. Need new thermostat? A job for owner?
#2 Posted : Thursday, March 19, 2009 2:05:27 AM(UTC)
Replacement parts for WHIRLPOOL RES7648KQ0 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406692.pdf
Here is a good site with basic dryer repair info
http://www.applianceaid.com/dryers.html
A job for owner?
Depends on how handy you are and how much effort you want to put in.
This is a possibility. The Operating Thermostat has a small heater built into it, on lower heat settings this heater is turned on. This adds heat to the thermostat, it turns off more often and this reduces the dryer heat.
So if it is open you get only high heat.
The thermostat's heater also has a variable resistor (cycle switch) in series with it, this varies the heat output of this heater.
First check your vent system
Undo the dryer from the exhaust
Run a load
If the unit now has low heat then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
Unplug the machine for the following;
Next remove the wires from the main heating coil. Measure with a meter from each heat contact to ground. Should be an open circuit. This is checking for a grounded element re: it has sagged or broken and is touching the case so it is always on. You could remove the heater assembly and check it visually.
Next remove one wire from the thermostat's heater and measure it's resistance, Should be approximately 7,000 ohms.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
jenny55
#3 Posted : Thursday, March 19, 2009 4:48:11 AM(UTC)
jenny55
very helpful - thanks
Amana Refrigerator Thermostat? (Refrigerator & Freezer Repair)
by yaworski 3/24/2021 10:42:55 AM(UTC)
Problem with thermostat? (Dishwasher Repair)
by tstewart100 1/29/2016 2:49:52 AM(UTC)
Bad Cycling Thermostat?? (Dryer Repair)
by 69_Eliminator 7/18/2015 9:38:22 AM(UTC)
fuse? limiter? thermostat? high limit? (Dryer Repair)
by sunshine5500 2/20/2014 11:50:29 AM(UTC)
Dryer Thermostat? (Dryer Repair)
by SynchHD 11/9/2013 1:23:11 PM(UTC)
How exactly do I replace the thermostat? (Oven Repair (including Ranges and Cooktops))
by Pattie076 10/2/2013 2:33:42 PM(UTC)
To keep thermal fuse from blowing, can I substitute a lower temperature thermostat? (Dryer Repair)
by MargretS 7/21/2013 2:43:23 PM(UTC)
thermostat? compressor? something else? (Refrigerator & Freezer Repair)
by cstultz 7/14/2013 4:12:37 AM(UTC)
Dryer not heating enough - cycling thermostat? (Dryer Repair)
by sherfield2002 12/27/2012 3:51:55 PM(UTC)
Bad Thermostat? (Refrigerator & Freezer Repair)
by miguel622 9/27/2012 9:20:57 AM(UTC)
Ice on coils: Bad defrost heater, or thermostat? (Refrigerator & Freezer Repair)
by jcw2 1/3/2012 12:32:25 PM(UTC)
Do I need a new thermostat? (Refrigerator & Freezer Repair)
by qwkteg125 10/20/2011 11:25:45 AM(UTC)
How Do You Test A Control Thermostat? (Dryer Repair)
by ddraker 7/11/2011 11:07:19 AM(UTC)
Freezing in refrigerator. Damper or Thermostat? (Refrigerator & Freezer Repair)
by bdcs64 6/8/2011 8:34:08 AM(UTC)
Dryer running too hot... bad thermostat? (Dryer Repair)
by tireshark 6/1/2011 5:42:01 PM(UTC)
