tstewart100
#1 Posted : Friday, January 29, 2016 2:49:52 AM(UTC)
tstewart100
Have a Gibson GDB635RHSO dishwasher that keeps sticking halfway through normal cycle. Will continue if manually advanced. Replaced timer control,no luck. Replaced element no luck. Now the thermostat, I see one on the left that has 2 red wires,one to the thermostat and one to the heating element, I guess this is the Hi-temp thermostat-replaced this and now when I run unit with hi-temp wash and rinse option selected the timer goes to the same place and delay start light comes on and dishwasher just keeps running, Is there another thermostat somewhere on this model I can't find? Parts list shows Hi limit switch which I replaced but also shows a thermostat? Thank-You in advance
#2 Posted : Friday, January 29, 2016 6:50:26 AM(UTC)
Parts for Frigidaire GDB635RHS0 Dishwasher - AppliancePartsPros.com
[COLOR="Blue"]Is there another thermostat somewhere on this model I can't find?[/COLOR]
Yes there are.
Take a look lower left on the wiring diagram.
These two control power to the timer motor and are the wash and rinse temperatures.
To find them look in the parts and then search the parts for "thermostat"
I am not sure what you are looking at.
The hi-limit is item 29 in section 04.
tstewart100
#3 Posted : Friday, January 29, 2016 10:31:16 AM(UTC)
tstewart100
Thank-You Sir,
So I need to replace 29A on the right side which is the temp thermostat that I have already?
What I am asking is the location of F117-20 Temp assure therm and F127-20 the temp therm. Are they located under the tub or in the door panel?
Thank-You
