ddzc
#1 Posted : Wednesday, July 20, 2011 1:56:49 PM(UTC)
ddzc
Hey everyone,
The water remains on the bottom of the dishwasher after each run. I cleaned the water out and cleaned the junk in the filters and such, re-ran the dishwasher and it clogged up again, wouldn't drain.
I want to pull it out and inspect everything, but the front hose is holding it in. Picture here: http://i3.photobucket.co...ms/y92/ddzc/IMG_0670.jpg
Does anyone know exactly what this hose is used for? I'm in a condo and I don't have a main water valve. I shut off the water valve for everything under the sink which I thought runs to the dishwaser but the water keeps running with the valve off...so I don't want to remove this hose until the water is completely shut off...not sure what to do at this point. Any suggestions?
ddzc
#2 Posted : Wednesday, July 20, 2011 2:31:59 PM(UTC)
ddzc
I also tried cleaning everything...followed this video: Bosch Dishwasher Not Draining Repair Help Online » ApplianceRepairLesson.com
#3 Posted : Wednesday, July 20, 2011 4:25:36 PM(UTC)
Where the drain hose is connected to under the sink?
