Hey everyone, The water remains on the bottom of the dishwasher after each run. I cleaned the water out and cleaned the junk in the filters and such, re-ran the dishwasher and it clogged up again, wouldn't drain. I want to pull it out and inspect everything, but the front hose is holding it in. Picture here: http://i3.photobucket.co...ms/y92/ddzc/IMG_0670.jpgDoes anyone know exactly what this hose is used for? I'm in a condo and I don't have a main water valve. I shut off the water valve for everything under the sink which I thought runs to the dishwaser but the water keeps running with the valve off...so I don't want to remove this hose until the water is completely shut off...not sure what to do at this point. Any suggestions? Thanks
Where the drain hose is connected to under the sink?
