nativenyer
#1 Posted : Monday, March 16, 2009 12:05:24 PM(UTC)
nativenyer
I need to replace the control panel on the above. Will I need to cut off the gas and electric or just unplug the wires from the damaged unit and
plug them into the new unit and remount?
#2 Posted : Monday, March 16, 2009 1:15:48 PM(UTC)
Here are the parts
Replacement parts for MAYTAG PGR5715BDW | AppliancePartsPros.com
This should help
http://www.servicematters.com/m...ibrary/docs/16010161.pdf
Definitely unplug the unit or you may need another board.
Not sure about the gas.
replacing oven control panel (Oven Repair (including Ranges and Cooktops))
by brad 8/2/2007 12:04:59 PM(UTC)
