nativenyer
#1 Posted : 16 years ago
nativenyer
I need to replace the control panel on the above. Will I need to cut off the gas and electric or just unplug the wires from the damaged unit and
plug them into the new unit and remount?
#2 Posted : 16 years ago
Here are the parts
Replacement parts for MAYTAG PGR5715BDW | AppliancePartsPros.com
This should help
http://www.servicematters.com/m...ibrary/docs/16010161.pdf
Definitely unplug the unit or you may need another board.
Not sure about the gas.
replacing oven control panel (Oven Repair (including Ranges and Cooktops))
by brad 17 years ago
