Billie87
#1 Posted : 14 years ago
Billie87
I use my inglis electric dryer on regular sensory dry always and it has recently started acting funny. After it has finished the cooling cycle it will continue to the wrinkle prevent and where the time remaining usually appears there will be a rotating circle and the machine will beep, a single beep, repeatedly. The clothes will be dry, so I've just been stopping it at this point... what is going on? what does it mean? Please and thank you!
Joe / APP Team
#2 Posted : 14 years ago
Joe / APP Team
Billie,
Sounds like normal operation.
Check and make sure, someone has not selected the " Wrinklr Prevent" option. :
Wrinkle Prevent Wrinkle Prevent provides approximately 95 minutes of intermittent tumbling in unheated air at the end of the cycle to reduce wrinkling. Press the Wrinkle Prevent pad to activate this feature. The indicator light above the pad will illuminate when Wrinkle Prevent is selected. Chasing lights appear in the display when the Wrinkle Prevent option is selected (select models). The load is dry and can be removed at any time during the Wrinkle Prevent cycle.
You also need to cancel that option, after the cycle, or it will remain active for all the successive cycles.
Good Luck,
Billie87
#3 Posted : 14 years ago
Billie87
Thank you so much!!!! I feel like a total idiot!:o :D The worst part is that I called their stupid customer service and they had no idea how to help me... Much appreciation! :) :) :)
Joe / APP Team
#4 Posted : 14 years ago
Joe / APP Team
Billie,
Glad things were that simple.
We're more than happy to help,
Thanks, and Good Luck,
