ronkat
#1 Posted : 17 years ago
ronkat
My son broke the exterior glass of the oven door. We placed an order with GE and received a replacement glass. However, there are no instructions about how to install the glass for the oven door. Help?
#2 Posted : 17 years ago
In order to provide the most accurate advise I need the complete model number of the range. XL44 is not a valid model number.
ronkat
#3 Posted : 17 years ago
ronkat
the model # is JGBP85CEA1CC
Thanks and hope you can lead me to a way to install the glass on the door.
ronkat
#4 Posted : 17 years ago
ronkat
Model #JGBP85CEA1CC
#5 Posted : 17 years ago
Remove the screw on each side of the door, holding the door to the door hinge and remove the door.
Place the door on the flat surface with the door handle down. Do not let the door to rest on the door handle. You have to find out by yourself which screw to remove first because I do not remember the sequence.
- Here are the break down diagrams for the GE range Model JGBP85CEA1CC
ronkat
#6 Posted : 17 years ago
ronkat
It looks like the front glass door is glued to part #314? If so, what kind of glue is used?
#7 Posted : 17 years ago
I do not think you have to remove this part.
The door has to be disassembled from the inner panel side.
