ronkat
#1 Posted : Friday, November 16, 2007 3:08:54 PM(UTC)
ronkat
My son broke the exterior glass of the oven door. We placed an order with GE and received a replacement glass. However, there are no instructions about how to install the glass for the oven door. Help?
#2 Posted : Friday, November 16, 2007 3:38:00 PM(UTC)
In order to provide the most accurate advise I need the complete model number of the range. XL44 is not a valid model number.
ronkat
#3 Posted : Friday, November 16, 2007 5:38:46 PM(UTC)
ronkat
the model # is JGBP85CEA1CC
Thanks and hope you can lead me to a way to install the glass on the door.
ronkat
#4 Posted : Sunday, November 18, 2007 9:47:28 AM(UTC)
ronkat
Model #JGBP85CEA1CC
#5 Posted : Monday, November 19, 2007 9:55:13 AM(UTC)
Remove the screw on each side of the door, holding the door to the door hinge and remove the door.
Place the door on the flat surface with the door handle down. Do not let the door to rest on the door handle. You have to find out by yourself which screw to remove first because I do not remember the sequence.
- Here are the break down diagrams for the GE range Model JGBP85CEA1CC
ronkat
#6 Posted : Monday, November 19, 2007 5:48:46 PM(UTC)
ronkat
It looks like the front glass door is glued to part #314? If so, what kind of glue is used?
#7 Posted : Monday, November 19, 2007 5:54:05 PM(UTC)
I do not think you have to remove this part.
The door has to be disassembled from the inner panel side.
Guest (8)
