trbandy
#1 Posted : Sunday, March 15, 2009 1:17:40 PM(UTC)
trbandy
Installed new thermal cut-off but did not install new thermostat because instructions were unclear about wiring. First load dried just fine, but the new thermal cut-off must have gone out on second load because dryer quit drying again. Bypassed thermal cut-off and dryer works fine, wonder what happened that thermal cut-off went out on second load. Do you have to replace thermostat each time you replace thermal cut-off or are there other problems I need to look for?
Vent is clear.
Lent screen is clean.
Dryer heats fine with old thermostat and thermal cut-off bypassed, but my understanding is that it is a safety feature and it needs to be hooked up right. Any help would be truly appreciated!
kayakcrzy
#2 Posted : Monday, March 16, 2009 3:45:29 AM(UTC)
kayakcrzy
Yes it does need to be hooked up. I have a few go bad on me, where the customer called me up the next day. But, I would replace the high limit thermostat that comes with it. Tom ApplianceEducator.com
Guest (4)
Replaced adc, now new problem (Refrigerator & Freezer Repair)
by matte 9/29/2014 7:01:16 AM(UTC)
ge 1800 xl new problem please help (Microwave Repair)
by andreah 7/5/2011 9:55:06 AM(UTC)
New defrost timer not defective but a peculiar new problem (Refrigerator & Freezer Repair)
by rbrimages 1/13/2010 6:47:54 AM(UTC)
Oven Pressure Regulator Replaced - new problem (Oven Repair (including Ranges and Cooktops))
by tracy@aconnectivity.com 2/11/2009 3:32:58 PM(UTC)
New problem for KERC607HBS8, replaced hidden element doesn't heat (Oven Repair (including Ranges and Cooktops))
by retrac 11/13/2008 7:35:05 AM(UTC)
New Problem (Dryer Repair)
by Blackboot 10/11/2007 1:43:50 AM(UTC)
