I can not figure out how to get the ice maker out? I have been having problems with the ice maker not working and water leaking everywhere. I think that I may need to replace the ice maker but I can not figure it out how to get it out.
Well without a model #, I would imagine that you have the one where the ice bucket is in the door. You did not give the model #. It helps me to know what you have. But, if you do have the ice bucket in the freezer door. Look underneath the icemaker at the white tray that it sits on, and there will be three 1/4 inch screws underneath to remove, and then one in the back right hand coner of the ice maker that has a little plate that covers the wiring. Once you remove it, pull it out and unplug it. Tom
