I am getting a Fault Code of F2 and F3 it shut my oven down in the middle of dinner!
Need a Model Number in order for someone to help you. Model Number Locator[URL="http://www.************************.com/0078.asp"][/URL] |
THIS FORUM IS DEAD!!!!!!! |
Unfortunantly those codes mean a clock control board and a sensor. The sensor is wired through the board. So you would most likely need the clock control board. But, if you are going to do the job, I would recommend replacing the sensor for another $45.00. Tom
ce6898vvv This is my model # should I get a professional for the timer board
Here is the error codes F2 - Oven to Hot - Replace relay board (if present) or bad oven temperature sensor F3 - Open or shorted oven sensor - Replace oven sensor Note am not 100% sure on the above. First I would try unplugging or tripping the breaker for half an hour or so just to see if it will reset. To check the oven sensor you will need a meter. Following is a good site with general stove repair help. see #7 for the temp sensor http://www.applianceaid.com/elecrange.htmlCannot advise on getting in a pro as I do not know how handy you are at this type of thing. One thing is for sure do not mess with it when it is plugged in. |
