mzummallen
#1 Posted : Friday, March 13, 2009 5:11:36 PM(UTC)
mzummallen
I am getting a Fault Code of F2 and F3 it shut my oven down in the middle of dinner!
#2 Posted : Saturday, March 14, 2009 3:29:03 AM(UTC)
Need a Model Number in order for someone to help you.
Model Number Locator
[URL="http://www.************************.com/0078.asp"][/URL]
kayakcrzy
#3 Posted : Saturday, March 14, 2009 4:26:39 AM(UTC)
kayakcrzy
Unfortunantly those codes mean a clock control board and a sensor. The sensor is wired through the board. So you would most likely need the clock control board. But, if you are going to do the job, I would recommend replacing the sensor for another $45.00. Tom
mzummallen
#4 Posted : Saturday, March 14, 2009 4:35:04 AM(UTC)
mzummallen
ce6898vvv This is my model # should I get a professional for the timer board
mzummallen
#5 Posted : Saturday, March 14, 2009 4:39:15 AM(UTC)
mzummallen
#6 Posted : Saturday, March 14, 2009 7:25:59 AM(UTC)
Here is the error codes
F2 - Oven to Hot - Replace relay board (if present) or bad oven temperature sensor
F3 - Open or shorted oven sensor - Replace oven sensor
Note am not 100% sure on the above.
First I would try unplugging or tripping the breaker for half an hour or so just to see if it will reset.
To check the oven sensor you will need a meter.
Following is a good site with general stove repair help. see #7 for the temp sensor
http://www.applianceaid.com/elecrange.html
Cannot advise on getting in a pro as I do not know how handy you are at this type of thing. One thing is for sure do not mess with it when it is plugged in.
